I thought I would be slick and replace bilge pump and float switch with one that had both in same housing. I purchased a rule-mate 500. It has three wires. Black to ground. Brown to automatic. and Brown/White for manual. It is design to use a three way switch. My leads run directly to battery bank with no switch in between. I hooked up the auto side to the postive lead and the black to the negative. The float would not engage the pump. Manual side works fine. Why would the auto side not work directly hooked to battery. I am clear as mud?
