I acquired a 19' Mariner through Marriage. It's been out of the salt water for 5 years. Two problems.The Keel won't come down in the water. The trailer set up wouldn't allow this check on land (rollers and braces in the way). I didn't really think this would be a problem anyway, since the keel weights in excess of 300lbs, according to specs. Certianly the design is weak (rusting pot metal) but I would have guessed that gravity would break any rust scaling problems.1) Do I have to put it in a sling to fix this?2) Who has a 'tool' or method to free up the keel?3) Is this a dry land fix?The rudder and tiller have disappered since it last sailed. I've looked at on-line sources to replace and the two I've seen are outragous! (in excess of $500 for a rudder and tiller for a $2000 boat!). 1) Are there plans available for the original set-up?2) Is a kick-up rudder really necessary with a 6' keel?The transom on the boat has been broken and repaired because of the kick-motor bracket. My though was to put a teak or similar harwood beam accross the transom and link it to the hull. 1) Anyone performed a better fix?2) Anyone ever had a serious problem with a seperation of transom and hull?Any advice is appreciated.Thanks
