O 25 Rudder
Sending second request, not sure I did the first one right. recently acquired a 25 oday, and found out the rudder is to short as it is not original..If anyone has specs I will appreciate it very much so I can correct the problem. Height, length and width..thanks dennyg
The O'Day 25 had at least two different Rudders, maybe more, while in production. What year is your boat?
Then the actual drawings and specs on the Rudder are available from the Ships Library at Mystic Seaport for coping charge. Also available is a spec sheet on a kick up rudder for the 25 designed by the designer of O'Day 25, John Deknatel.
There is also a company that sells a kick up rudder for the 25, but it is a bit pricey. All the above can be found in the archives of this site. And, maybe more informantion.
Understand that original drawings are copywrited so are not on this site.
Ed K
O26
