Hi all,
I am the proud owner of Rivendel II a Hunter Legend 43 from 1991. I am in the process of bringing her back from a 10 year stint sitting in a marina.
I was a tad concerned when I saw the rudder tube wobble a couple of weeks ago so I removed the tank to find that the top section of the rudder tube had separated from the deck under the quadrant. The core has failed through years of water entering and now needs to re-cored and glassed which I gather is a considerable task.
I can’t seem to understand where the upper bearing is located. If a fellow hunter owner could look at one of the attached images of the quadrant and advise if that white sleeve (which seems seized to the stock) is the upper bearing that would be greatly appreciated. Could it have come free from the deck, considering the poor state of the fibreglass, and seized itself to the stock??
Does anyone have a cross section or diagram of the rudder section on this boat showing how it was made and where the bearings/bushers are.
I just want to get all my ducks in a row before I do the job and try to avoid any unpleasant surprises (although I’m sure there will be a couple) when she come out of the water.
Any advice at this stage is GREATLY appreciated…
Thanking you all in advance,
Luigi Anselmi
Rivendel II
Luigi Anselmi
Rivendel II
