So I mounted Bottoms Up's rudder the other day. Discovered I needed a 3/16 clevis pin and retainer, which I ran out and bought.
It seems the upper portion of the rudder has 2 holes in a vertical line and the tiller has 2 holes near the rudder end in line fore and aft.
I see the holes on the rudder for the downhaul and uphaul lines, and it is obvious the uphaul runs to the tiller and the downhaul to the upper rudder section, but does the line just pass through the holes or do I need to find cleats to mount there?
