rudder repair
Jim Beckle
Rudder is cracking due to water inside freezing over the winter. Any suggestion on how to repair the rudder would be greatly appreciated.
Jul 12, 2004
285
Catalina 320 chestertown
I had that problem once. First look at the probable cause. Most production boats use rudders that the maker recommeded they be painted white, not blue, black or red. Why -- when the boat is out of the water the rudder collects heat from the sun and then falls apart. Once it goes back in the water it fills up with water. In any even, you get the idea. The fix is to drill holes in the rudder, fill it up with epoxy, put screws in the holes to reshape it until dry. Once dry, take the screws out, finish it off then paint it with white bottom paint or keep it covered with something white when it is out of the water. At least this is what I did to mine several years ago. Good luck. Paul
F
FrankR
I just repaired a crack in mine
I drilled holes at the begining and ending points of the cracks and about every 2 inches along the crack. I injected a thickened epoxy mix (cabo-sil) into the holes and let it dry. I added a strip of fiberglass over the length of the crack extending 2 inches all around the crack. (sand with 80 grit paper beforehand). I then built up layers (about 3) to cover the weave of the fiberglass. Sand smooth with 80, 100 , 220 paper and recoat with bottom paint.
