H
Henry Weber
The rudder post on a Hunter-33 1980 was bent about 15 degrees by a recent hurricane.The rudder now is inoperable because the bend causes it to strike the hull. The bend in the SS shaft is down inside the fiberglass near the top of the rudder. My plan for repair is to either a) split the rudder in two by cutting around its periphery allowing removal of the stock or b)remove enough of the top part of the rudder to expose the bent area of the 1 1/2 inch SS pipe(stock). This would allow access to staighten the pipe.I would appreciate any suggestions as to how to proceed. I believe the rudder is fiberglass on its outside and then foam between the glass and the stock, but I am not sure. Is the foam a special hi-density type or can I use the aerosol can HomeDepot variety?
