Rudder removal and repair
11
- - Guinness
Does anyone know the procedure of removing the rudder on a 1982 Hunter 27? I have a obvious blister problem on my rudder. I thought it would be easier to remove the rudder and bring it home for repair, since I live far from my boat. I was tolled I sould drill holes in the rudder and let it dry out. Does that sound right? Thanks, Don
Jun 2, 2004
425
- - Sandusky Harbor Marina, Lake Erie
REmoving the water
The rudder should float if it's not totally waterlogged. I you are in the water, dive to secure it with carefully with a rope, then release it, and force the post down until it floats free of the boat. To release a rudder in the water or on the hard (for a tiller model - you'll need someone else'a advice if you have a wheel) is pretty simple. Remove the tiller. Remove the bronze fitting that attaches to the tiller. Then remove the retaining ring that is fastened to the post with a through-bolt, and rides on the teak bearing. You can hold the rudder for a moment by squeezing the post. Then it will just fall through the hole. If you are on the hard, you need enough clearance under the boat to get the post out of the boat. This usually means digging a hole under the rudder to create the clearance. Or you could arrange to take it off while the boat is in the sling, or on a lift. There are some posts in the archives here about draining the rudder by drilling holes, and then refilling them - I suggest you search there. David Lady Lillie
