I think my rudder got bent when being towed off a sandbar last week.
I had the boat hauled and it's on a stand.
I have removed the quadrant and cables.
Rudder will not drop.
I understand there are two bearings as seen from the pix attached
From the pix there are 2 bearings: 1 at the hull that is in the glassed tube and the 2nd one is above the lazerette shelf. On my boat the lazereete shelf up to the top where the emergency tiller access is also a glassed tube.
So due to the glassed tubes I do not have access to the bearings.
Am I correct that I need to cut off the glass tubing at the lazereete shelf to get access to the bearing. Is it holding the rudder in place with a through bolt or something.
Well I was wrong there is nothing to cut!!. If you remove the screws for the for the collar of the inspections plate at the top where the access is for the emergency tiller. Remove the collar you have access to the bolt that holds the rudder shaft on. Very simple!!!
Please any advice is very welcome.
Kevin
