I just rebuilt the rudder on my H23. After last season i found cracks on the leading and trailing edges so i ground them out, filled them with resin and microbaloons, reshaped, and laid 2 strips of glass all the way around the edges front, rear, and bottom and feathered them in. now it is time to repaint and re-gel. my question is: which should i put down first....2000E or gel? the gel is hard as nails and i will roll both on. also, it looks to me like it wouldn't hurt to lay a base of finish resin down on the complete rudder before i do either just to give some additional sealing and smoothing and then sand it before laying either the gel or 2000E. recommendations?william
