I am about to begin rebuilding the rudder for my h28.5. I have some questions on some how tos.
1)leading edge has split stanard water issue I have dried it out removed all bottom paint and sanded smooth I plan on cleaning out the crack and filling with interlux water tite is this appropriate??
2) the bottom has been re glassed but it eas my first attempt and i have cut it open to let it dry my question is do i have to use fiberglass mat and resin to repair or can I fill with polyester resin fortified with west 407 or is it better to use west epoxy fortified with 407
3) also I have some areas the have seperated from the foam that I have drilled out to fill with epoxy what type of product do I want to use for this? biggest area of seperation is less than 3/16 of an inch
I plan on coating the entire dudder with interprotect to stop any water and i would like to have these areas as sound as possible
