Michel
This picture display the current installation on my Hunter 430. As you can see the rod is connected under the flywheel and the denivellation is more than the 5 degrees Raymarine specification. The rod is also bent and in contact with both the hull and the flywheel.When the wheel is turn fully, sometime it cause the rod to disengage from the tiller pin.Anybody could provide me tips for a better installation?Regards
