Yes, but . . .
WTA, I have a h23 with a kick-up rudder, and I'll be the first to admit it can be annoying to have it kick-up underway. But I would be more annoyed if it simply broke off in the down position. The reality is that my rudder, which is held by a line through a cam-cleate kicks up only when it hits something. The h23 only drafts 2'3" its keel, but the rudder drafts around 3'-3 1/2'(this is admittedly an estimate, at 6' tall with a proportionate arm span, I can't touch the bottom of the rudder extending as far underwater as I can with my face barely at the surface). Consequently, the keel may clear an object, but the rudder is still at risk. If Sheridq has a similar setup, allowing for the rudder to kickup may keep it intact. Jim Kolstoe, h23 Kara's Boo
