Looking at Ed's picture has gotten me thinking. Might be that what's needed is th shorten by about 4 to 6 inches, add about 6 inches aft, and then add some to the forward edge below the level of the propeller. That might retain the easy balance it has stock. jibseaman; can you get that done and report back to us on your findings by mid March? That would give me time to get it done if it works for you. If it doesn't I'll be happy to offer encouraging words.
Technique for loosening stuck bolts: apply heat, and spray the hot part with PB Blaster or similar penetrant. An electric heat gun is really good for this, better than flame. A few cycles usualy gets the job done. Don't go crazy with heat to the point you damage the foam or glass of the rudder. Last resort: DRILL the HEAD off the bolts. Punch dead center and use a drill bit slightly larger than the bolt diameter. Much less colateral damage than a Sawzall. Also smack the bolt heat a few good raps with the old ball peen. Helps loosen things and let it know who's boss. Use never-seize on new hardware. I use it every time I bolt metal to metal, regardless of alloy.
