I have had an issue with my rudder since I got the boat in 01. The boat is a 1995 Hunter 37.5. When under power the wheel wants to turn to port. This I had thought was due to the force of the propeller being uneven on each side of the rudder. Last year, while on vacation, I happened upon a surveyor who suggested that the rudder had probably been repaired some time before I had bought the boat and was repaired incorrectly. Basically he suggested that the two sides of the rudder were not symmetrical thereby causing the rudder to have more lift on the port side than the starboard side.I have also detected some rust spots on the leading edge where the internal structural members are. I know there has been water infiltration over the years and I have done my best this year to seal all of the cracks with Marine Tex then barrier coat before painting.My question is can I or should I replace the rudder? Can I simply call Hunter and order a replacement?Any thoughts are welcome.
