Catalina went through several iterations of rudder stops on the 310
At first, my March 2001 Hull #147, had single light cables on each side to mounting points under the swim platform deck. I *****ed about how flimsy it was and they upgraded to a heavier cable yoke with anchor points on the vertical bulkhead of the swim platform.
The next time I had it in to clear the extensive defect list, they went to the rubber bumper on the same anchor post with wooden stop blocks bolted and glassed to the upper bearing tub.
The rudder design on the 310/320 makes it amazingly maneuverable since the rudder will turn 80-85*. I can turn my boat in its own length and keep doing figure skater twirls under power if I wish. Few non sport boats can do that.
The penalty of course is that if you are backing and let the wheel get away; it will come up HARD against whatever stops you have. With either of the cable systems if you will stretch/break the wire and hit the hull. Hard enough and you can bend the rudder post. Even with the blocks you will ultimately break something. Any boat will do that, but the additional 30-40* on ours magnifies the load remarkably
I love the Captain Ron maneuverability and you just need a firm grip on the wheel...
Peter
