Rudder Dinging
Oct 30, 2014
7
Pearson 27 Somers Point
If I put an extra long (25") shaft Tohatsu outboard on my 1980 O'day 22, would there be a greater chance of the propeller dinging the rudder than with the 20" long shaft? Thanks
Beneteau 323 Annapolis MD
If the rudder pivots are vertical to each other, then probably not more of a concern than long or short shaft. If the rudder pins are at an angle, but aligned to each other, then it would not swing on a vertical axis, an maybe would hit the prop.
