Tim
If you read the Foss Foam website they advise painting the rudder white to lessen the chance for the rudder to overheat and delaminate from the sun while the boat is on the hard. Listen to this advice.My boat is on the hard and the rudder has been laying on the ground for about ten days. A rock snuck up under my boat and wiped out the original rudder and I am waiting for a replacement. The post is bent and it is unrepairable. Aside from some damage to the lower tip of the rudder it was in good shape with no delamination when it came off of the boat. I was surprised last night to step on the rudder only to find the skin to be completely delaminated. The rudder is garbage so to me it does not matter but I thought I would share the results of my unintentional experiment. It has been sunny but the air temps here in my area have not exceeded 80 degrees.Tim
