Rudder bushing
Bill
Is there anyone out there that has an older model hunter where the rudder bushings have given you a problem, and what did you do to repair it. My upper rudder bushings housings was damaged at some time and know it moves, and it's time to fix it.
Dec 3, 2003
2,101
Hunter Legend 37 Portsmouth, RI
I Had One Made
I had to replace mine in my '88 Legend. It wasn't available to purchase, so I have a friend who volunteered to make one for me. He measured the hole and the shaft with a micrometer and had his shop in Mexico produce it for me. My problems were solved. This was done about 10 years ago.
Dec 2, 1999
15,184
Poly board?
Bill: Can you get some poly board and just drill out a hole that is just slightly larger than the rudder post. Then just bolt or screw it into place. If this is exposed to sun light I would use seaboard or one of other similar products. It it is NOT exposed, then a cutting board works fine. Seaboard, Kingboard and the likes all have UV inhibitors to prevent degradation in the sun.
