Hi guys,
I am in the process of replacing the rudder bearings on our Hunter 30T because of wear. Having removed the rudder I was told by Hunter tech support that the bearings can be knocked out with a long bar - top bearing from below and vice versa. On examining the bearings I have found that the top bearing is trapped within the rudder tube by the deck? ie. The hole in the deck is the same size as the bore of the bearing, so I cannot tap the bearing up and out from below. (the bottom bearing is the trapped the same by the hull) I guess these are the original bearings (1990) so my question is; Do I enlarge the hole in the deck, to the bearings outside diameter, inorder to remove it? There doesn't seam any other way and looks like no forethought for easy removal was ever considered. Has anyone else come across this design in their boats? How did you resolve it?
Any help would be much appreciated. Shaun.
