High All, I own a 2005 c310 Hull 314 and during a recent hawlout noticed movement in my rudder post. Question is do I replace both bearings and if so can the correct ones be purchased. Or should I use Part Z3244 Rudder Bearing Epoxy Repair Kit. Has anyone had any experience with the epoxy system and if so how good have you found the repair?
Thank you
Cam
Thank you
Cam
