Noticed some minor gel-coat stress cracks and repaired them with a Beneteau color matched gel-coat kit. I finished the job (wet sand) first with 400 then 800, 1200 and finally 1500 grit sand paper. Question? When I finished my sanding with the 1500 the surface looks pretty glossy however will using a hand applied rubbing compound make the shine better or worse than 1500?
Thanks
Thanks
