Rick Harvey
Re: 37CWhat function do the Teflon pieces on each side of the rudder have?I found the bottom screws had pulled due the sealifes new home and revealed a 1/8 hole into the hull. I find it unbelievable that these are thru holes. I have removed the plates and built up the hull 1/4". I don't intend to reinstall these pieces unless advised other wise.Rick.
