Rubber Battens
John Drost Jr
Has anyone used rubber for sail battens? I have some stiff rubber that is 3/8" thick. TKX John.
TOM MANALILI
YOU'VE GOT TO BE KIDDING
AT AN INCH THICK IT STILL RUBBER. the problem lies in the design of the pocket not the battan.
P
Paul Akers
I won't shout...
...but I'd stay away from rubber. A batten will slide or bend within the batten pocket while sailing. I feel that rubber would cause too much chafe and eventually cut you sails at the pockets. You can buy batten material and caps at WM, to make your own, fairly reasonable.
