Rub Rail replacement
I think that you have a different rub rail than the one on my OD 222 which is made of metal, but it is probably put together about the same way as mine. If I was going to remove mine again I'd probably do it the same way that I did when I found that it was leaking and needed caulking. I didn't take the complete rub rail off. Instead, I removed parts of it at a time, caulked it, and reinstalled it. On my boat; The rubber comes together on the stern, and is held in place by two screws. Remove the screws and start with say,-- the Port rubber. Remove it from the track as far as where there's a joint near the bow of the boat. In other words; there's probably at least three sections of molding on your boat that are butted together, and not one complete molding. This is how mine is put together. I would suggest to you at this time that if you're going to remove the rubber and fool around with the moldings, you may as well re-caulk the entire molding all the way around. Rudy told me that the caulking only last about ten years. So if you never did it before, you should really do it now. All the screws that hold the molding on are under the rubber. If they didn't use all the holes in the molding when they attached it at the factory, simply mark each hole where there is a screw. At any rate. You should do one side of the boat at a time. Clean the area with a putty knife, and caulk and replace the molding, and re-insert the rubber. Then pull the rubber out of the Starboard side, starting from the stern. Of course, you're going to need to replace the damaged rub rail where ever needed, as you work each side. I'd use a good Polysulfide caulking such as 3-M Marine Adhesive Sealant Fast Cure 4000 UV. I prefer this over other brands of caulking, because I believe that 3-M has a longer shelf life than other brands that I've tried. It's not that hard of a job, really. I found that it was better to do the job in sections, rather than to take the molding completely off the boat all at once. You'll get the whole thing done and it's all going to fit. Maybe your rub rail being PVC, is one complete piece that butts in the stern, but where you have damaged rub rail on both sides, it will be easier to do one side at a time. Good luck with this. It isn't as hard as you think, and you'll knock it out in no time flat.Joe
