I bought a 23' Oday last summer. This is my first Sailboat...other than my sunfish. The boat is a '77 and has been sitting in a slip for the past 3 years with only a few daysails in that time. I spent the rest of last summer just enjoying the boat and was planning on fixing it up while it was out of the water for the winter. One of the repairs I need to make is to the port side rub rail. There is about a six foot section that has been torn to shreads by a piling while it just sat for the past 3 years. I'm having a problem finding replacement rub rails. I can't seem to find the same rub rails that are on my boat. I'd like to replace just a portion of the rub rail, but if I have to, I would consider replacing the entire rub rail. Either way, I'd like to use the same rub rail that was originally on the boat. Does anybody have any suggestions about where I can find them? None of the websites I've found have had the same ones that are on my boat.
Also, I desperately need to waterproof my lifeline stanchions. I have to pump a couple gallons of water out everytime it rains. Does anybody have any suggestions for what to use to waterproof them? The only thing I've heard is that you don't want to use silicone because it's not so fond of salt water.
I can't wait to get back out on the water this spring, but I want to make sure I get a lot of the work done on the boat before I put it back in the water. Thanks for any help you can give me.
