Rub Rail installation
Rob Davis
Does anyone have any pointers to installing a new rub rail on an Oday 222. It seems pretty much straight forward, but confused about bending around rear and front corners, and there seems to be sealant in the front corner where rail does not touch the fiberglass. What type of sealant is this? Thanks Rob
Trevor
Rubrail
Hi Rob - It may be easier to install the rubrail, around the corners especially, by heating it up. Either use a heat gun or soak it in hot water. Regarding the sealant, I don't know what the original materials is, but you could use something like Sikaflex 4200 (tough, but removeable if you ever needed to do repair work down the road). Best of luck, Trevor
Rob Davis
Thanks
Thanks, I'm still trying to get in touch with Rudy from D&R. Its looks like he has the NOS rubrail and I want to get it so I can see how rigid it is. If thats all you need to do to bend around the corners, then it should not be that tough. Thanks Rob
Bill Coxe
New Rubrails
A friend and I installed new rubrails on our boats this spring, mine an ODAY 28 and his an ODAY 35. We got everything from Rudy, including advice, which was okay, but didn't prepare us for the total amount of physical effort required. First, make sure you are not alone. Two, fill all the old holes with caulk and DON'T use 3M. The flexible stuff from West Marine or anyone else is more than adequate. Also caulk the new holes as you install the rail. The plastic rail is sent rolled in the reverse direction and it takes a lot of effort straightening it all out. We believe that it takes a heat gun, not a hair dryer, to make those turns and we're still not sure about the poper technique, but persevere and it will look great. You will also end up adding strength to the hull-to-deck joint (all those extra screws). Installation of the rubber insert itself is fairly straightforward and you don't have to be very gentle. Like so many other "learning experiences", you can talk about it but until you do it... Good luck, Bill Coxe, O28 Kukulcán, New London, CT
