Rub Rail H340 Remove , Reseal, Replace
Nov 27, 2019
1
Hunter 340 2 St. Augustine Fl
I have a 2001 H340 and the rub rail needs a little TLC or possibly replaced. I am also not sure if she is sealed underneath at deck/hull joint. My desire is to remove, reseal and possibly replace. Has anyone attempted this ? Do they make a suitable replacement ?
Rub Rails often are placed on a base which is attached to to the boat joint. The rub rail then slides onto the base. Like this.
Here are a couple of other designs. And a link to more - TACO Marine. Hunter Marine
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
I assume your 2001 is similar to my 2000 410. I have replaced the rubrail around the stern. if you are trying to seal the hull/deck joint like i did it is a project. You can private message me and I can tell you more.
Likes: SVSandrajean
Levin
Apr 7, 2007
165
Hunter 340 San Diego
If you just wanted to clean the rub rail the Mr. Clean eraser pads do an amazing job of this. You burn through them pretty fast on the rub rail but I was amazed at what a difference it makes.
Take care,
-Levin
