Another C30 Owner Says
It is a 3000 maximum rpm engine.80-85% of LOAD is the sweet spot.Rpm is not the same as load, but it is the most practical gauge we have.That makes 2400-2500 rpm the "deducted" preferred operating range.Caveat: don't put blinders on, and adopt a mindset that this is the only acceptable way to use your engine. Yes, your diesel likes to run under load, and will give a longer life if it gets to do it for a large percentage of its clock time.But practical considerations in the real world mean there will be plenty of accumulated hours on your motor that were not in that optimum range. Marinas have speed limits/wake restrictions for a reason, and if the argument "I have to keep my engine running at 80% of its max" informs all your motoring, you will become a discourteous and dangerous boater when steaming. And there are plenty of other reasons to operate your MX25 outside that range. Sure, it's less than "optimum," but out of the thousands of hours of potential service of your engine, you will only be taking off a small percentage. Diesels are rugged by design.When you're out in the open, find that sweet spot range. But know that your engine will forgive you for having to live in the real world.Fair Winds,Jeff
