Route & weather planning
Feb 15, 2008
230
Hunter 49 Sydney
Im looking to see if todays Geeks or Technocrats (probably includes me at some level) have found any Sophisticated weather planning and routing tools.
In today’s age there is no reason a lot of the hackwork cant be done for us or for those that are keen to invest some time into it. However, Im unaware of just what is out there any better than what I have.
I have a reasonable tool currently in built into what was Raytech an expensive Raymarine PC chart plotter, that most hated but I always found it very useful and now wouldn’t be without it. It will take a route, pickup your polar(if you have it) pickup an ocean current grib, and the typical weather grib that some are used to and from that it will plot what it believes is the optimal route, based on a start date and time within your weather grib file range. At a basic level its not to bad and if you like messing with this sort of stuff it can actually be useful.
However today with starlink and data that's out there, there is no reason why a much better tool should not be available. I personally have not used the paid or subscribed version of predict wind for example so perhaps it has everything , but essentially there is no reason why you could not just plug two (or more) way points in, feed a start date range and a polar of your boat, some sort of current file, tell it to avoid x rain, greater or less than x & y wind strength , and avoid depths less than 20m., ie the things you might do in your own planning, assuming your not a shoot from hip and just go. kind of captain.
I keep a few years’ worth of grib files and while historic weather clearly doesn’t promise tomorrows weather its still quite useful to look back at cyclones ITCZ zone movement, typical cloud and rain, which times have more of particular wind you might be seeking, or normally a better angle etc.
I have recently fired a bit of this sort of stuff into AI including things like 3 months visa restrictions, least cyclones, predominant wind angles , least rain, how long I will spend in each country, etc etc and the results are interesting, but Im just wondering if there is already something more sophisticated out there already around the weather.
If you believe you have something more or equal to what I have already I would be keen to hear
I use a group of data sights and the weather models the produce. We have different resources than what is available Down Under.
Whether sources and forecasts include the info from the US NOAA data bases. A comparative picture of current forecast weather patterns to judge sailing conditions for a 3-4 day period
Windy app from the European creators. Same weather forecasting concepts but with a hi probability of conditions for a 6-8 day period.
And LuckGrib an open source project with very reasonable in purchase upgrades. The Data used is the same as publicly provided.
LuckGrib then solves for the weather between two points "Start" and "Target" to create a routing with course headings and points of sail, based on the weather data (grib files) and the sailing data of the boat (polars).
Likes: JamesG161
Feb 15, 2008
230
Hunter 49 Sydney
I haven't invested lots of time into other products at this point but it seems from afar that the practicality hasn't matured yet in many fronts. Ok routing through shallows or over land is being picked up now and yep luckgrib has motoring Polar ( I have 3, sailing, motor sailing & motoring) and using different grib models is essential because ECMWF down under is not a great model. But hey Im looking at roughly a 2 year trip, from Ozy, to New Cal, Fiji, Marshalls, Micronesia, Palau, Indo North(Wiag), and back to Philippines. So yep starting from Ozy its a no brainer wait till after cyclone season.... But when exactly, can I start in March, yea probably to early, in April, yea better, in May I should be gone. But lets call my desired product "Routing Heaven" or "RH" So I make a route from say Southport in QLD to New Cal (about 800nm ENE) and I run RH across a years' worth of historic Grib files and it ask it to give me the top 10 best times to leave based on distance and time. So nearest to 800nm and 5.5 days which is straight line. This shouldn't be rocketing science. So now I know roughly the month to leave. Then when I get to the month, I run real current gribfiles through, so while I sit in Southport waiting for my weather window I know what Im trying to get to. Rather than me running through each day for the next week, it should be able to look at 10days and say, leave Tuesday, and you have and 850nm route over 6 days. Then lets face it in my case if I see bunch of heavy rain ahead I wil plan to go around it or slow down if I can especially at night. If the Grib file has precipitation or rain etc you should be able to say avoid etc like luckgrib does or has for blocking out area's. I don't know about you guys but that's typically what I do manually. These things will drive weather I reef at night, how much how soon etc. Then where my existing routing planning software also falls down it doesn't take into account what I actually have. So RH said leave Tuesday the Grib file said the wind would be SSE, but in fact it ESE, so now I cant sail the predicted wind... Pun intended. Same goes for currents. Some route planning seems to take into account how hard or keen you are to sail, ie how fine a tack.
It just seems we haven't progressed very far even though we have alot of good Data available.
dLj
Mar 23, 2017
4,636
Sounds like you want a computer to drive your boat.
Weather prediction is darned good 3 days out, pretty decent 5 days out, getting pretty dicey 7 days out and as far as I'm aware, no models will even give you data more than 10 days out.
The best modeling seems to happen closer to shore. I've found looking at the models and being in the middle of the ocean, they get less accurate out there.
For trip planning further out than about 5 to 7 days there are no computer generated models - best method I'm aware of is using the pilot charts I mentioned above.
dj
It’s possible to get the GFS model data for up to 16 days out as gribs. Whether days 10-16 are accurate enough to be trustworthy is anyone’s guess.
Over the winters I participate in some races at Sailonline.org - Online Sailing. That’s a fun way to practice routing and play around with new tools. The most commonly used tool there is qtVLM. It’s free/open source and very configurable for things like night/day performance differences, motoring, etc.
BarryL
May 21, 2004
1,087
Hello,
I believe that all of the serious racers use Expedition Software
It's expensive.
Predict Wind also does what you want. it's a lot cheaper than Expedition.
I have used this site for checking the gulf stream current.
that site also includes the latest weather forecasts.
Barry
Sep 30, 2016
390
Island Packet IP 44 Ventura, CA
I use PredictWind. It seems to do a pretty decent job, with a max forecast of 10 days out. You can build a basic route, ask it to give forecasts for 4 departure times, minutes, hours, days apart, and see which ones look best. Then out of your pick of basic departure time, you can run a different module that will show recommended routes based on 6 or so weather models. Lots of number crunching, lots of data. I mostly just look at the graphical displays and the trip summaries. I use the standard plan.
dLj
Mar 23, 2017
4,636
I haven't seen any indication that the models are trustworthy beyond about 5 days.
I always use all the models, I run the simulations, compare what they all say. If they are all in close agreement, then things are likely pretty stable and the predictions are probably pretty good – I'm talking out 5 or so days.
Weather models are not going to help you plan that trip 2 years out. Use other sources of data. Essentially I classify the two data sets – the long term data (LTD) sets that are not computer models, and the short term data sets – the computer generated weather prediction models (WP). You can't use the WP models for time frames beyond the approximate two weeks they give you.
As I'm planning a trip, I start with the same general idea of what month is best to start looking using the LTD. I'll start then looking two or three weeks ahead of tentative departure date using the WP and watch how the models develop. I'll look every day ahead of the tentative start date. The actual date will be modified depending upon the weather predicated from the WP.
I don't understand this comment? Long term computer modeling of weather patterns is way beyond rocket science....
Like I've said above – the current WP models are not accurate beyond about 5 days.
As I run Starlink, I'm running the WP data every day while at sea. I never rely on this data to decide how I run my sails at night. I rely on my direct conditions using my own eyes and senses. I will typically reef at night simply to avoid having to do so in the middle of the night....
I find my own observations from my boat to be far more accurate than any WP data on a daily basis.
I personally feel one needs to be a sailor first and foremost when sailing offshore. The data models are nothing more than a tool that may or may not work for where you are. All critical systems on a ship need redundancy – the best redundancy for computer generated weather prediction is the human mind. Learn to use it.
That's my 2 cents worth...
dj
When to go? When to stay? When to hide? When to get a beer? Tell me oh Magic 8 ball what should I do?
You are correct. The machines, while helpful in providing statistical probability, such as “there is a good chance if you jump in the water right now no shark will nibble on your leg,” can not tell you the safest moment to untie the lines and set sail.
In LuckGrib you can control the report to tell you how these primary three modes "Sail only", "Motor only", or "Motor/Sail" will best get you to your destination. The algorithm works according to your preferences. For example: Identify the route that will allow me to sail to my polar's, yet if the boat is moving less than the specific minimum sailing speed (you can tolerate), say 3 knots, turn on the motor and plan for 6 knots to my destination. Even with this information, my confidence level is only 4-5 days in the Northern Hemisphere.
It is not AI, nor is it perfect.
Grib files (your data source) are available for most of the planet. They are a model of data.
The Austrailian Marine Wind forecasts "ACCESS-S" are based on a 99-member ensemble. This is a common climate forecasting technique in which the model is run 99 times with slightly different initial conditions to capture a range of likely future scenarios. It is a best estimate projection of the current known data into the future. While similar to the Euro model it uses different levels of data with varying levels of quality. Windy has been programed to use the Euro model in the distance weather routing mode.
Windy reports weather in the area surrounding Australia using ACCESS-S data.
I haven't invested lots of time into other products at this point, but it seems from afar that the practicality hasn't matured yet on many fronts.
I would agree with this observation.
The conditions that make up the weather are ever-changing. Your historical database will be helpful from a macro view. 'Sail in April after the cyclone season.' But the week or the day to leave is determined by current data. For example, we are just learning about the effect of the 2022 Tonga Volcano on the planet's weather in 2024. ("Tonga’s volcanic eruption could cause unusual weather for the rest of the decade, a new study shows" — Tonga’s volcanic eruption could cause unusual weather for the rest of the decade, new study shows) Such events can disrupt the best weather planning.
This only points out the imperfect nature of weather forecasting. One needs to use a lot of high-quality data to teach an AI program how to consider and place value on the varying conditions. At the same time, the AI program must consider your boat, the skills of the skipper, and the crew in the mix. That is a lot of computing power and a lot of data to compile. it feels reasonable to say "the practicality hasn't matured yet on many fronts."
The skill of the skipper is still a vital element of safe navigation. :)
Feb 15, 2008
230
Hunter 49 Sydney
Thanks to all and a lot of good thoughts and in response
No Im not looking for a computer to drive the boat, but I would be keen for it to do what I do manually, which I would check of course.
Yes I agree weather prediction further out becomes less accurate, but its what we have to work with. I just want to make the most of it.
There are forecast models beyond 10 days . Viewfax (16 days) which I believe pulls its models from Sailmail, which I think comes from NOAA will produce grib files for 16 days. Of course as suggested the accuracies of such are getting slimmer each day. But be that as it may, it’s a better guess than say 90% of us or me for sure. The Pilot charts won't help if there is a depression, or cyclone, they do nothing for a trend or low developing. Good for ball parking expectations. For cyclones/typhons Ozy wont raise any flags until its within 5 days. This is criminal in my personal view and sometimes it even comes down to 3 days. There happy to say in a normal forecast wind strength can be up to 40% stronger, but they not happy to say there is a 40% chance of a cyclone coming 6 plus days out. As a lay person I can see this coming at least a week out
Yes agreed weather models are of little help for 2 year trip. However I wouldn’t say no help. Jimmy Cornells world routes has some basic Tradewinds weather planning and there is a heap of info in Pilot guides etc but while I don’t want to get into “climate change” here in my view a number of the old traditions are dyeing, and the season expectations are moving. A lot of this information in 15-20 years old. Yep agreed you can't use computer models for a 2 year trip. But with historic grib and ocean data I can run this through my route plan in Raytech historically and see for example that for the last two years there is a good chance I could get jump on the season even in late March. OpenCPN has a climatology plug, sadly it stops 2010 due to lack of data sources, but even here you can see the shift in traditions. Its a pity is data source dried up
My everyday forecast I get for 10 days typically one model unless I see anything suspicious or Im planning a passage, then multiple models out as far as they will go. The upside here is that while the forecast for day 5 and beyond might have the wind direction and or strength wrong, its not so often that it completely misses a big low or high development.
Yea not my experience at models in Oceana being better in shore. In fact if you asked me, I would have said the reverse. When I have questioned the BOM ( Ozy weather forecasters), there standard answer is the forecast is being effected by the land. As far as Im aware there modeling which is run locally in Ozy doesn't take on much to do with land, other than perhaps the land mass. You can see this easily by examples of the lack of offshore winds at night as the land temperature drops the wind races off shore and is seldom shown on weather models
Yea I’m not meaning to suggest long term weather forecasting isn’t rocket science, Im trying to say pulling all the data together with some user filters defiantly isn't rocket science and shouldn’t be that hard
In regards to starlink and everyday Weather prediction. Yep for sure in my case it’s a good guide that I will use to drive my starting point. If Im in route for a few days, or even setting off and the weather model says anywhere less than about 12 to 15 I will run full sail at night (given I have radar to see squalls) If my weather says 20 knots is coming at 3:00am, then probably just before dinner or shortly after sun set I will reduce the sails to suit 30 knots. Based on the reef early moto.
I will have a look at qtVLM & see if I can find some detailed info on Expedition
Im surprised no one has really mentioned Predict Wind till now and so far the only one suggesting multiple departure times over a 10 day period using multiple models.
Yep Im not looking to ditch common sense, observations, or skippers' good skills , that we all should have as sailors. But I am looking for tools to do what we (or perhaps I do) manually and to do it better and more reliably, so I can spend more time enjoying the trip. Im not looking to push auto pilot and expect it all to happen.
Im looking for as many of these aspects as I can get.
  1. To run route planning on any weather forecast model available.
  2. For it to use current and wave information
  3. For it to use my boat information via Polar, sailing, motor sailing, or motoring
  4. For it to run over a 16 day window
  5. For it to run retrospectively if the user can provide the data
  6. For it to contain filters for say wind strength, precipitation, swell height, wind angle
  7. For it to provide comparisons based on different models
  8. For it to realize if I motor for two hours while the wind changes is far more efficient than sailing 20 miles south to then sail 20 miles North when I could have motored 10nm directly While the wind turns.
  9. To export or provide the proposed route in a form I can lay on my chart plotter
  10. To realize on day 1 when the wind angle is 30 degrees out compared to the forecasted planned route and make the route change with real wind angle data.
As I said none of that is rocket science and the data is available. Dare I stir the pot by suggesting it seems like in regards to the weather we are still back to the equivalent of using paper charts and a sextant for navigation
So who’s product comes closest ??
Is this not all useful information??
This book provided a decent insight into the evolution of weather prediction.
From your list, the following are available in the LuckGrib software:
I have used these features to provide weather data updates to a boat crossing the Atlantic.
    1. LuckGrib provides multiple models and data elements to download and utilize in solving for a sail route.
    2. A record of the down loaded files is maintained and can be updated.
    3. If you have internet access, you can get detailed data. If bandwidth is limited, you can get reduced data.
    1. currents and wave data are download options.
    1. Your boat's database is used to filter the route solution. You can even identify how close you want to sail to reefs or a land mass.
    1. The window is based on the available weather data downloaded. Sixteen days would be a large file. Not all weather database files provide a sixteen day window.
    1. Not Available to my understanding
    1. These filters are available if the data is provided in your Grib file.
    1. You identify the Grib file model to be used. The program will create a route between Start and Finish. Multiple models are available.
    1. This is not an automatic feature. The program uses the existing wind data to tell you to motor when the conditions are not expected to meet the parameters set for sailing. As you experience changes you update the Grib file and then solve for the new start to destination target.
    1. You can export it to a GPX file and download it to a Chartplotter.
    2. You can print out a detailed report of wind data and bearings, sail tack, etc
    1. Not part of the program capability. You would need to update the weather data and rerun a solution manually.
Likes: JamesG161
Feb 15, 2008
230
Hunter 49 Sydney
Thankyou, sounds great and a good step forward.... Oh nothing for windows it seems, IPad I don't have or use, Mac, thats like asking a mono owner to move to Cat, yep phone I sure do have, but it would have been nice on my big screen Kbd and mouse etc where I do all the other Nav stuff that is also replicated at the helm. But cant have everything, I will see how it goes. - Thanks again for the feedback
Feb 15, 2008
230
Hunter 49 Sydney
Ah it seems Luckgrib not available on Android or Windows :(
Seems Predict wind is the next choice
dLj
Mar 23, 2017
4,636
Copy
These longer day forecasts are useful for altering your course to avoid major storms, as best one can given the limitations of your particular boat speed. Something to think about. How far can you actually travel in, say, 5 days to change where you are going to avoid a storm? Now if you are in a Pogo, you will have a much larger range compared to my boat that only runs 6 to 7 knots.
I recall coming out of the Azores and we were looking to avoid a hurricane that was predicted to come crashing down on us from the north in about 3 to 5 days (uncertainties of the different weather prediction models). Our great circle route would have had us running right through the bottom of that storm – on the less desirable side...
I had one crew with me that was a competent sailor and we had a very good working relationship. All decisions we made were an agreement between the two of us (we had a third crew with us at the time but a novice so she simply would listen in on these conversations). As we were leaving Horta, I said I think we should head on a much more southernly route giving us as much time as possible to put distance between us and the storm. He countered saying maybe we should head closer to the great circle route and if the storm did start to get close, we could then drop south.
I asked him how far did he think we could get and that perhaps it's better to simply be where you want to be rather than hope to arrive to where you should be.... We went south and had a spectacularly beautiful trip. A day off the coast of Portugal and the three of us looked at each other and said, rather than going to land, perhaps we should just turn either North or South and keep sailing – this is just to lovely to have end....
Yes indeed, not to get into “climate change”, but weather patterns are changing. The pilot charts are 15 to 20 years old but they are based on over a century of data collection. Of course the better information within those are in the regions with higher shipping so heading to regions outside of that has greater error. And that is not portrayed in the data presented – it's only implied. I've had the same concerns.
Unfortunately I don't know of a better data source. Getting this data from the past, say 5 years, and using it to essentially make more accurate pilot charts would be something very useful to the greater sailing community, I would think.... I wonder if something like that may be in the works inside the large institutions that house the data that make the current pilot charts. It would certainly be a useful data set for modern shipping.
That is the main utility of these models. Avoidance of major storms.
My statement comes from deep ocean – I'd agree with you when speaking to areas closer than about 200 nm from shore.
I found in the middle of the ocean, the weather models were at best approximate to representing general conditions. As in, no I'm not in gale force winds. But wind speed and direction had a notably larger deviation from what I was actually seeing compared to closer to shore.
Copy
To each their own. I run conservatively. I tend to reef before dark running into the night. Of course if weather forecast predicts a significant weather change, I will adjust.
I think because Predict Wind is so well known and extensively used, no one thought to really mention it. Predict wind has all sorts of functionality used by cruisers such that it's almost a given it's a known entity in the cruising world. If you were not aware of Predict wind, you would be so far down on the learning curve that most of this conversation would be rather academic.
Are you a solo sailor do you sail with crew? As a solo sailor you can set up and run any system you want, interface with it however you want. If you pick up crew, there may be the need to make sure crew agree with the complexity of the system you are looking to implement.
You mention “more reliably” and “spend more time enjoying the trip”. I question the greater reliability. I think it simply adds complexity but I doubt it adds reliability. “Enjoying the trip” - that depends upon what you enjoy doing during the trip. Technology, especially complex systems, tend to create tethers. If you enjoy those tethers, great. But you may find it becomes more of a burden.
I strongly disagree with your analogy.
I'd suggest you look at the sailboat racing community. Ask high end racers what they use. I had a crew on board who was in that category and he had his computers with him sailing with me. A lot of your above list of desires I know he could do through his computer system, but I don't know what it was called. He did not have the historical weather data you are looking for.
That's rather an ask for opinions.
Points 1, 2, 3, 6, 7, 9 already exist. You are not asking for something new.
Point 8 could be improved, but does currently exist.
Point 4 – I don't consider at all useful. The data is not sufficiently accurate to be useful that far out.
Point 10 I find amusing – It's actually asking now for the integration of on-board weather sensors as you may be sitting at day 1 and can see the change you mention, but the computer model is still saying the incorrect real world situation.
Point 5 is actually the only thing on the list I personally would find interesting – but I would want you to show me where that data is, because as you have written it, “if the user can provide the data” is useless.
dj
I understand the focus on computer systems. Over the last 4 years, I have moved from 40 years of mainframe/PC/Windows-based systems to embracing the difference of the Apple structure. It was sweet to discover LuckGrib.
This just came up on my screen.
DeepMind AI predicts weather more accurately than existing forecasts
The latest weather forecasting AI model from Google DeepMind can beat the leading providers more than 97 percent of the time, and it is quicker and cheaper to run
You may get your wish to have an AI weather forecaster on the boat.
