H26 Rudder
Thanks to Juice for reminding us about the rudder. I pin mine in the same position each time I go out but I'd forgotten that a lot of trial and error went into getting just the right setting at first. Here's a 1994 article from Rob Mazza the designer of the hunter trailerable rudder. There is a picture with the article, but Juice does a good job explaining what it shows."RUDDER BALANCE AND WEATHER HELM ON HUNTER TRAILERABLESDo you think your boat has too much weather helm? Too much lee helm? The problem and the solution may have nothing to do with the balance of the boat and may be related directly to the balance of your rudder.The two subjects of rudder balance and weather (or lee) helm are closely linked even though they are, surprisingly enough, totally unrelated. Rudder balance refers to the amount of rudder area extending forward of the turning axis of the rudder and affects how much load you will feel on the tiller. For instance, very little balance will create a very "heavy" or highly loaded helm, while too much balance will create a "lightly" loaded helm. If you try and Steer a Hunter trailerable with the rudder raised to horizontal you have felt an extreme case of heavy helm! If balance is increased too much, that is the blade raked too far forward, the helm can even become "over balanced" so that if you let go of the tiller the rudder will continue to turn or "capsize" in the direction it was initially turned. This can be a little disconcerting, to say the least, and demands constant attention to steering.Weather helm, on the other hand has to do with a different type of balance - the longitudinal balance between the center of effort of the sail plan and the center of pressure of the hull, centerboard and rudder. If the sail area is too far aft, the boat will tend to round up or head into the wind. This is weather helm and should always be present to some degree. If the sail area is too far forward the boat will bear off or turn downwind. This is "lee helm" and should be avoided at all cost. Too much weather helm is manifested by a heavy load on the helm as you fight to keep the boat from shooting into the wind. Lee helm is evident when you let go of the tiller and the boat falls off and continues to head down away from the wind instead of up into the wind. Weather helm means you are always pulling on the tiller; Lee helm means you are always pushing on the tiller. This assumes that you are sitting where you are supposed to be sitting when going upwind - on the weather side of the boat. The link between these too unrelated subjects is the load on the helm. Even the most experienced sailors can confuse an under balanced rudder with excessive weather helm or an overbalanced rudder with lee helm. So, before you start panicking and moving your mast to solve a problem that may not exist, check your rudder blade position.The Hunter 19,23.5 and 26 all have pivoting rudder blades to allow the rudders to be raised for trailering. That means that the owner can literally dial in the amount of helm balance he or she wants to suit the conditions of the day. The rudders were designed with the flat on the back of the top of the blade parallel with the back of the rudder cage. This gives a good all 'round balance. Raking the rudder aft will reduce balance and increase load on the tiller, which may be desirable in very light air. Raking the blade forward will increase balance and reduce helm load, which may be desirable in heavy air. However, beware of excessive forward rake and an overbalanced condition, which will need constant attention and will create a lee helm feel to the boat.The rudder blade is adjusted by loosening the rudder clamp "wing nut" on the side of the cage and adjusting the blade angle with the continuous lift and pull down lines and reclamping the wing nut. Remember to never tie the pull down line to the cleat on the bottom of the tiller when the rudder is lowered. This will prevent the rudder from "kicking up" if you run aground or hit a log. If the rudder is not allowed to kick up, damage to the transom at the lower gudgeon will result upon grounding. The cleat should only be used to tie the rudder blade in the up position for launching and trailering.So remember, the load on the helm can be more of a function of the correct adjustment of the rudder blade than the location of the sail plan. Play with rudder rake and see the effect."
