My boat has wire to rope halyards. The rope has an eye splice this is run through a crimped formed eye in the wire. Both the wire and rope are in good shape except at this connection the wire seems to be cutting the rope a little. The big problem is this connection is rubbing the mast making a grove in the mast. This is happening on both jib and mainsail. I know this connection is usually woven together some how. Can I do that or is there a better way to connect these then what I have? I can't afforf to replace them this years as other things needed done to the boat that ate up to much money. If not water hose covers will be used for now. Thanks in advanced Greg
