Room around the table H 30
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Our new to us (1989) Hunter 30 has not enough room to scoot around the table. I'm thinking of building a new table, cutting the original down, or repositioning it on the post (which also requires cutting a deeper compression post notch.) Have others done this project? I was surprised a web search didn't find it to be a common modification.
Ken
Oct 24, 2010
2,405
Outstanding. Thanks for the links.
Thanks again. Lots of ideas.
I guess I've decided to just build a new table. That way I can make it a shape and style I want. One issue I've had was I made the mistake of pricing teak locally. Wow.
So for now I plan to just use birch plywood, cover it with laminate, and finish the edges with teak veneer. I will also likely install some teak rails to keep things from sliding off.
Ken
Dan_Y
Oct 13, 2008
524
Hunter 36 Hampton
Ken,
Does your table have a folding leaf that when down gives better access thru the companion way to the vee berth? The table is large in the '91 as well so it can be lowered and rest on the edges of the seats to make a big bed in the salon. Please post what ever you come up with... I'm way interested as well.
Dan
