We can all thank boating forums for bringing this serious issue to light!! We should also thank West Marine for stepping up even when the manufacturer failed to do so.
Bottom line is that Steve Bambury/Hold Fast CHANGED THE SPEC that Peter Smith the designer insisted upon. Some of the Chinese made Rocna's have been showing up bent and the steel used to make them is well under the designers intended specification.
If you have a British Columbia built Rocna or NZ built Rocna this does not affect you...
If you ant a great anchor buy a Manson Supreme!!!
