I did the topside (above the rub rail) on my Tanzer 26 last spring. The paint kit (primer, thinner, paint) came out to $380 for a quart kit. I needed a little more than a quart of primer (2 coats). You have to paint while it is cool (not cold). Sanding between each coats. If it gets too warm, it will turn dull. I am pleased with the results but it is not perfect (I know where the drips and runs are, mostly in the primer layers which are hard to remove with sand paper). The prep work takes time and effort (I removed all of the hardware and had the stanchion bases and cleats powder coated). I rolled mine on with microfoam rollers (I did not tip the rolled surface), but the solvents in paint additives tear them up and they start falling apart. I used 12-15 rollers in two coats of primer and two finish coats. If you spray, be careful with the overspray... it travels. You need to wear a VOC respirator and tyvek suit; very toxic stuff. The final coat went on when it was in the 50s and was almost misting. It came out perfectly.My 38' Catalina is in need of a paint job. Due to the high cost of a professional painter, I am planning on rolling the hull this spring. Any advice on how to roll awlgrip would be extremely hellpful. Thanks
Good point, I found 180 to work best for rough areas with a 220 follow up, much faster and very nice results.... Awlgrip calls for sanding with 320 between coats but we get better adhesion using 220. ... Chuck
