Paul Palmer
My 1977 OD25 has a jib lead forward mounted to the deck with out a track and a track mounted lead aft by the cockpit for a Genoa. I was planning to install a track for the forward lead block for better sail adjustment but am also planning on adding a rollerfurler with probably a 130 or 135 genoa. How much do you use the forward lead block with a rollerfurler? When the sail is reefed to working jib size or smaller can you get by with the genoa lead or do you always change the lead to the forward block? Thanks for the info.Paul Palmer
