Roller Furlor binds
Aug 10, 2026
2
Pearson 1970 28 Bullock Cove
I have a Harken furlor on my Pearson 28. Operated flawlessly for 10 years. Now it binds frequently when I am taking the sail in. I will usually find a knot or bind in the spool. Back it off and and push it around loosens it than it furls in. The line itself is in good shape with no signs of abrasion or knots or kinks.. This is new over the bast month or so. No changes to the set up in the interim. It comes out fine. Any ideas?
JBP-PA
Apr 29, 2022
831
Jeanneau Tonic 23 Erie, PA
Did the fairlead shift positions? My did the same thing until I realized I accidentally moved the first fairlead so it wouldn't wind up smoothly.
Have you washed the accumulated dirt out of the furler line recently. Dirty line stiffens and can swell making a smooth wrap on the furler drum impossible. Line jambs, over wraps occur and a smooth operation fails.
Sep 24, 2018
4,788
Catalina 30 MKIII Chicago
If the housing of the line is catching on the housing of the furler due to the housing shifting X degrees (think of it like a clock), it can have similar symptoms as well. Dirty bearings are another possibility that nobody has mentioned. Many possibilities but most solutions are quite simple.
2
OK all. I checked the fairlead and think I found part of the problem. So re rigged it at a better angle As for a clean line I checked and part of it is a bit stiffer. Not bad but definitely not soft like new line. So I am going to clean the line. Since it is kept on salt water I'll probably take it home and wash in clean fresh water.. After all this we'll see what happens.. Thanks Very Much to ALL
Jan 7, 2011
6,013
Oday 322 East Chicago, IN
The line on my old furler would get stiff as it aged and got dirty. Thought the furler was the problem, until I put a new furler line on and it worked great.
So, wash the line or replace it and I bet you will find it works much better. But also rinse the drum and bearings with fresh water…that can also make it turn easier.
Greg
dLj
Mar 23, 2017
5,231
When you wash your line - soak with some fabric softener.
dj
Likes: Tally Ho
Jun 21, 2004
3,222
Beneteau 343 Slidell, LA
Greg,
I have found the same. After 3 or 4 years, I have to replace my furler line. It looks ok; however, the stiffness & reduced flexibility affects the furler operation. Washing it helps a bit, but a new line is the ultimate solution.
Unfortunately, contrary to popular belief, the lines that are on a boat when new or newly purchased are not life long attachments that stay with the boat til it is demolished.
They are like batteries in a smoke alarm. They need replacement at least every 10 years. Sooner if the boat is actively sailed and put through harsh conditions, like raced in a stormy ocean.
Mar 26, 2011
4,045
Corsair F-24 MK I Deale, MD
Unfortunately, contrary to popular belief, the lines that are on a boat when new or newly purchased are not lifelong attachments that stay with the boat til it is demolished.
They are like batteries in a smoke alarm. They need to be replaced at least every 10 years. Sooner if the boat is actively sailed and put through harsh conditions, like raced in a stormy ocean.
:yikes: OMG!
Well, I did replace some of them, with stuff left coiled by the skip.
  • Ha
4,045
dj
That helps, but more effective yet, is a wash-in water-repellent treatment. Lasts longer, works better, and the line dries faster, which means less lime accumulation and less mildew. If you sail in the winter, it means they don't freeze. You do it in a bucket, not the washer, and skip the drier step. Also, the dregs are reused with a booster dose to treat line after line.
dLj
Mar 23, 2017
5,231
Got a link? Never heard of that.
dj
The jib sheets are 14+ years old, nice and supple and no wear. No need to replace them. The rigid vang line is getting a little ratty looking, but still works well.
The wire rope halyards did get replaced 13 years ago, the new halyards are still good, no plans to replace them any time soon.
The main sheet did get replaced, the old one was stiff and worn.
This after 10K + nm on the water.
May 29, 2018
692
Canel 25 foot Shiogama, japan
RE PO Original post.
A knot? How did that come about?
Gary
Sep 24, 2018
4,788
Gary
How'd we all miss the part about a knot? A twisted line sounds like the most likely cause
