E
Ed Larmie
I just purchased a 1987 O,day 272 and it appears that the line (jib halyard) that should run inside the furling tube had pulled out. Plus it looks like the rope cover is worn and needs replacing. The big problem is that it appears that the plasic traveler end of the line was molded to the rope when it was made. Has any on had this problem? Any Ideas where you would purchase a replacement line with the traveler molded on or how to go about coming up with replacement traveler end. Right now the line is stuck at the top of the mast so I would like to have some ideas before I go up there to fix it. PS do you know what the line size should be.Thanks,
