I have a new roller furling head sail on my boat. 135, Dacron, no sun shield material. The sail lives under a zip up sunbrella cover to protect it from UV. The sail maker said it would last longer and keep better shape if the sail was all sail material and the cover was a separate sock.
My old stock Catalina sail had developed a hook in the leech where the (original equipment cheap) UV material was. That hook was in the direction that the sail rolled around the furler.
So my question: should the direction that an RF sail wraps around be reversed now and then so that the sail does not acquire a 'set' from always being rolled up the same way?
OC
OC
