Roller Furler
21
- - Chicago, IL
I have a 1994 vintage Harken roller furler. It furles in the Genoa nice and
smooth. When unfurling it seems to hit a "flat" spot ever revolution and
you have to really pull on the sheet to over ride it. Any ideas what could
be causing the issue.
Thanks
RJ9757
Jun 15, 2004
29
- - San Francisco
Headstay tension?
If the headstay is too loose, it could cause the problem you describe.
I also had a problem once with the jib halyard being too tight, which also produced similar symptoms.
Good luck!
