Rolled furling not rolling up enough
Mike 1
Sep 19, 2010
62
Hunter h27 Sandusky,Ohio
I have an '82 Hunter 27. It has a rolled furling headsail and I noticed when I roll the sail I only get about one or two full wraps of line around the sail. I have read that you should have a few more then that. I am not sure how to make that adjustment. Thanks!
Beneteau 323 Annapolis MD
When the sail is deployed, wrap a couple more turns of the furling line around the furling drum. Two more wraps around the drum should be two more wraps of sheets around the sail.
Oct 2, 2008
3,815
Pearson/ 530 Strafford, NH
Hi Mike,
We added more wraps by undoing the clew while it's rolled up and wraping the sheets around the sail the desired amount. It depends what is easiest or has the most access. We also have 4-5 wraps that never comes off the drum to take the strain off the knot holding the furling line to the drum.
All U Get
Oct 29, 2005
2,366
Mike, might be easier to bring both jib sheets up front and wrap afew more turns around the furled up jib (at this point your drum would be empty or have 1/2 to 1 turn of rope). You will notice that when you furl the jib in heavy wind, it'll roll up much tighter and if you haven't enough coil of furling rope in the drum you'll be left with some sail out when the furling rope is all drawn out.
zeehag
Mar 26, 2009
3,198
if your jib sheets are long enough, then is easy to wrap 3 or 4 times around the furler when furled. if they are short, then the furler wont roll as much. 1-2 wraps is ok if you are in a wind free zone.
Jun 21, 2009
110
Hunter 27 Sparrows Point
I usually wind up with a couple sheet raps from a starboard-side furl, and 3-4 from a port-side furl...or is it the other way around...? Anyway, as long as you finish the jib sheets with a figure 8 hitch back at the cockpit, your genny should be ok.
Mike 1
Sep 19, 2010
62
Thanks!
I stood there looking at it and thought, I know there is some simple way to do this,but i couldn't figure it out, DUH! Thats when I decided I would ask before I did something more involved! All of your suggestions are quick and simple! Thanks again!
