Rod rigging in Portland OR
Aug 8, 2018
1
Cal 34 MK III Vancouver WA
I have a sailboat project and purchased a used mast, which came with existing rod rigging. Where in reasonable distance of the Portland/Vancouver metro can I find someone who can service rod rigging (inspect and re-head for shortening after the mast is cut down some)?
Jan 5, 2017
2,263
Not getting a lot of response to this one. Fast Olsen is in your area and may know of someone. I would think that cutting the threaded end and cutting new threads would be the way to go. Just guessing!
@thebastidge try asking Passion Yachts on Hayden Island they may know someone. They have some bigger sailboats in their inventory.
Is there a reason you are wanting rod rigging? I have been told by my rigger that on his boat it had a shorter life span than wire.
It is a higher expense item to maintain.
You can convert the mast to cable rigging.
