Rigrt size prop for a 340
F
Floyd
We have a new (2001) Hunter 340 and looking at installing a PYI three blade prop on the boat this spring. What size prop fits the Hunter 340 and where can I buy one? Thanks Floyd
Dakota Jim Russell
PYI will advise
You can safely rely on PYI's advice. On my 340, I have a 16 inch Maxi two blade. You'll more than likely take a Maxi 16 inch 3 blade. The pitch is adjustable, and PYI will give you a table that calculates that for you. You will probably adjust it from that if you haul it out as mine was a little too much pitch. There is also a model of the maxi that is adjustable in the water. You may want to also consider that. But the bottom line, is that PYI will advise you of the correct size. Incidentally, your current prop is a 16x13 I believe, though you could check that quickly by emailing Hunter (see their connection on the main page of Hunter's Owners Web. Lastly, you'll love the feathering prop and find the 3 blade much smoother than my 2 bladed mode. Jim
K
Kevin
Three blade prop
Dear Floyd, Thank you for your note and interest in the Max-Prop. The recommended three blade is a 16” x 12” 1” shaft. In order to keep the site as non-commercial as possible could you please forward your request to me on my private e-mail address of kwoody@pyiinc.com. Thank you for understanding. Sincerely, Kevin L. Woody
