Rigid foam board
1,181
Allied Mistress 39 Ketch Kemah,Tx.
I have removed some panels for sanding and varnishing. There is a gap behind them about 1/2 to 3/4 inch. Would rigid styrofoam help and as insulation? Also, what would you use to stop the fiberglass from sweating.
Ross
Jun 15, 2004
14,693
TonyB consider the cause of "sweating"---------
The temperature of the surface is lower than the dew point. Therefore you have the option of, warming the surface, drying the air, or insulating the surface with a vapor proof coating. Car windows fog up when the glass is cold and the humidity is high. So we turn on the air conditioner and the heat. I think if you could find a foil faced foam about an 1/8th inch thick it would serve your needs. A 1/16 inch of foam will allow you to hold hot coffee in your hand. But you must prevent the water vapor from contacting the cold surfaces.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Insulation
Tony Home Depot has some foil faced stuff that is not a foam, but looks more like a bubble pack used for packaging. It is made for insulation, and has a fairly high "R" rating. If not mistaken, I think it has a higher "R" rating than the rigid foam. Beauty of this stuff is it is so flexible it can be put anywhere. I have bought some for my boat, but haven't installed it yet. It's not real expensive.
Ross
Jun 15, 2004
14,693
Bingo! install that with double stick tape
overlap and seal the edges and Bob's yer uncle.
May 11, 2005
3,431
No uncle Bob
Hey Ross, Bob isn't my uncle. He's Smilin Bob on the Extenze commercial, but no kin to me.
Jun 12, 2004
1,181
Went to HD and...
I went to HD and described the insulation that looks like buble pack and has foil backing. They looked at me like I was from a different planet. Does anyone here know the product name ? Tony B
Ross
Jun 15, 2004
14,693
TonyB I will check tomorrow and get the SKU
and send it. If they don't stock it simply insist that they order it for you. Also try Lowes.
May 11, 2005
3,431
It's called
Tony, The brand name on the stuff I got is " Reflectix" and they have a website. www.reflectixinc.com It is about 1/8 thick and from their label I think the R value for a stand alone application is 3.9 It did come from Home Depot
Jun 7, 2007
875
Pearson- 323- Mobile,Al
I saw some at Lowe's
It is Reflectx item number 13358 at Lowe's hardware store. Check lowes.com..
Ross
Jun 15, 2004
14,693
I checked at HD this morning and couldn't find any
But I know that it is out there.
Mar 20, 2004
1,753
Hd does sell It!
I got mine at HD, too-used it for insulating my A/C installation and made heatshield for the ports to keep the sun out
Jan 4, 2006
262
Catalina 36 MKII Buford, Ga.
another use...
My brother got this at Home Depot also. The HD store by me did not carry it. We installed this around 3 sides and the bottom of my ice box. This stuff is very flexable and easy to work with. We used spray adhesive to hold it in place. The final outcome is a very professional looking job. I won't know how well it helps insulate until next Summer.
Jun 12, 2004
1,181
GOT IT !!!!!!!
Thanks to everyone. Found it at Ace Hardware for a few bucks more than Lowes. I bought a roll. Actually GF picked it up. The 2 ft. stuff was $1.50 per foot or 1.05/ft if you buy the 50Ft roll. In addition to the 2'ft that I bought, they also had it in 16" and 4' wide. THANKS AGAIN Tony B
Ross
Jun 15, 2004
14,693
StephenK , You can find out this winter how well
it works. just go to the boat and boil some potatoes and see if you get condensate on the areas that you insulated versus the other areas.
Sep 19, 2006
643
SCHOCK santana27' lake pleasant,az
this stuff is water and mildew proof
check this out im putting this on the cowl of my truck and the hull of my boat. read what he has to say about this stuff
Ross
Jun 15, 2004
14,693
I would be inclined to add it to the ice box.
The weather is hot longer than it is cold in you cruising area and come summer tine you will be glad that ice lasts a bit longer.
