Rigid boom vang
Tim22
Jun 16, 2014
255
Hunter 310 Ottawa
I would like to install a rigid vang on my hunter 310 and would appreciate any suggestions as to which ones are most durable, easy to install, and work best. My main reason for doing this is to remove my dependency on the lazy jacks to support the boom as I'm looking at installing a cradle cover.
Thanks
Tim
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
I believe I am getting a Boomkicker but will still keep my soft vang too on my H30.
Mar 28, 2014
51
Hunter 31 Lake Norman, NC
Kito . . I believe you are on Lake Norman, correct? I'm also looking to add a boom vang to my '84 H31. I've subscribed to this thread. Minimum, I'd like to get a "soft" vang and I'd like to see how you have yours rigged. Can you share pics? Also interested in Lazy Jacks or cradle.
Tim22
Jun 16, 2014
255
Hunter 310 Ottawa
I have pretty much decided to go with the Selden rodkicker as they are the manufacturers of both the mast and boom. I am having trouble, however, identifying the mast section which is needed to select the fitting for the base of the mast. I contacted Eddie at Hunter but he says their info is simply MAST,SELD,STAND,H310. Does anyone know what the mast section is for the Hunter 310, or, the rodkicker mast fitting number?
Thanks
Tim
Oct 29, 2005
2,362
Thanks
Tim
There should be model/serial number scribed on mast and boom section.
Tim22
Jun 16, 2014
255
Hunter 310 Ottawa
I had a look on the mast for the model / section but couldn't find anything. Hopefully someone will know the mast section for the 310.
Thanks
Tim
jtm
Jun 14, 2004
313
Hunter 28.5 Dataw Island, SC
I have a K-1000 Boomkicker on my H28.5. Happy with it.
