Reading the Loos gauge...
...is easier than it looks. Insert the wire shroud into the heavy metal groove at the bottom, with your index finger hooked through the loop of string at the top. pull the string to you until the end of the 'finger' lines up with the last (heavy?) line on the scale. Read the number off the scale that lines up with your wire shroud at that point, and compare that number with the line diameter on the chart, and you've got your tension! I've noticed that it reads a bit differently if the shroud rubs along the side of the gauge, so I cock it a bit so the line doesn't quite touch. Remember to snug up both sides evenly, or else your mast will be cocked off to one side. Enjoy!Jim MaroldoOcean Gate, NJ
