Hello,
We just purchased a 1992 Macgregor 26s. This weekend I've been practicing setting the mast and figuring out the rigging in my driveway. After a few hiccups we were able to raise the mast using the mast raising system and it went relatively well. My question is in regards to the roller furler. I bought the boat with the jib sail rolled around the roller furler. It appears the jib halyard is run inside the the roller furler. The instructions show something about a pulley being attached near the point on the mast where the forestay is attached but I don't have that. The halyard is looped inside the roller furler assembly. Is this correct? Here are a couple photos.
I do plan on replacing as much of the rigging and hardware as I can as it looks fairly weak. I will probably be posting another questions in regards to that but for now I'm just curious to know if I need some sort of pulley up on the mast.
