I have a mast raising system that clips onto the two standup poles that support the rail. A rope leads to the bow and hooks on. the jib line is extra long and fits the pulley at the top of the mast raiser. I release the mast form the front and rear rails. Place the mast on the support and then I then pull up the sail. I set the rigging to make sure it will not get caught on anything and pull up the mast.
The only problem is when the rigging turns. Please look at photos. This happens to the rigging top and bottom.
Is there a trick to make sure the rigging does not turn?
