I have a few questions about a rigging modification I'm considering for my 1983 Catalina 30. When I bought the boat it was rigged as I describe below.
I have a self furling jib. I also have a smaller
light air sail but, with the jib up, no halyard to raise it. The
thought of taking the jib off to fly a light air sail doesn't make
sense to me. So I started thinking of rigging a line for the light
air sail. I have attached a document with an
illustration in it so I can be clear in my explanation.
Currently the #1 pin hole in the mast head is open.
#2 pin hole is occupied with the pin that the Jib is attached to.
My thought is that I would move the jib to pin #1, put a new pin in #2
and attach a block to it. Then I could run a halyard through that for
the light air sail.
My questions are:
Does this seem like a good strategy or is there a better alternative?
By moving the jib to #1 am I negatively effecting structure, stability
or reducing performance in any way?
What size halyard should I use?
Do I need to make considerations for the block I put on and what
interference it may have on the jib when out?
Any other comments or suggestions that you have would be greatly appreciated.
Thanks in advance
the light air sail.
My questions are:
Thanks in advance
