Yep
David, I did mine last year. I have hank on headsails. So everytime I use the lines run aft I think, "Did I really need to do that?" Its nice to drop the head sail from the cockpit but my main requires a bit of coaxing. I have to hank on and attach the haylards each time so afterwards I wonder was it worth it.ANYWAY, you will find photos in the archives under lines run aft. I put an organizing plate under the mast. It has a "wing" on either side of the mast with 3 holes in each "wing". To these are connected two blocks on swivels then as close to the hand rail as you can get is a three line organizer to turn from the 90 degree turn at the base of the mast back towards the stern. This is trickier than it looks. You want the organizer not to be running straight bow to stern but angled with he stern end angled back towars the center of the boat a little. This will keep lines from binding on each other as they leave the organizer. Mine is still a bit too close to the cabin roof slide. I hate the idea of drilling more holes in my otherwise solid boat. Then you'll probably want a rope clutch on the aft end of the cabin roof to hold the lines RMEMEBER TO LEAVE ENOUGH ROOM FOR A WINCH I barely did. I don't have a winch there and don't find it necessary right now. Might be handy to reduce sail in heavy air but . . . The hardest part was the organizer under the mast. It was the first time I had the mast down and I did it on the water. Moving boat, moving mast, many new dance steps. I bought all the hardware except the plate under the mast from Ruddy. No troubles. If you have more specific questions I'd be happy to tell you what I know.Good luck,Mike
